AutoCAD Architecture General Discussion
Active Member
0 Kudos
Post 1 of 12
Blank Yellow warning message
1719 Views, 11 Replies
08-21-2012 08:51 AM
Immediately after closing AutoCAD Architecture 2012 or AutoCAD MEP 2012 a yellow warning triangle with a black exclamation point displays. This happens every time AutoCAD is closed. However it is isolated to a few systems all of which were installed using the same deployment as the other systems that do not display this warning. AutoCAD performs as expected but displays this warning when closed.
Jeff
656 Kudos
Post 2 of 12
Re: Blank Yellow warning message
08-21-2012 09:39 AM in reply to: jeffthomasiii
Active Member
0 Kudos
Post 3 of 12
08-21-2012 12:12 PM in reply to: DarrenP
I tried that with luck.
Distinguished Contributor
2 Kudos
Post 4 of 12
08-23-2012 07:24 AM in reply to: DarrenP
FWIW, I'm using Win 7 Pro x64 and have the Building Design Suite installed (both 12 and 13). When 13 was installed then the warning message appeared on closing 12. I tried reinstalling MS .NET Framework 4 per links on this site and it did not solve the problem on my machine.
17 Kudos
Post 5 of 12
08-27-2012 07:20 AM in reply to: johnmacfall
I'm currently using ACA2011. Two weeks ago, when ACA2013 got installed on my computer, my 2011 install began exhibiting this same error upon exit (I'm not using 2013 daily yet).... twice, every time.
I'll try the above fix and see if it works
Paul
17 Kudos
Post 6 of 12
08-27-2012 12:33 PM in reply to: pkolarik
No luck here with that .Net solution....:smileysad:
Active Contributor
1 Kudo
Post 7 of 12
02-08-2013 08:57 AM in reply to: jeffthomasiii
I'm late to the party but just started researching this issue myself. I'm seeing this on my 64bit Windows 7 box running Autocad 2011. I also have Autocad 2013 installed. I'm sure that's they key to all of this. I tried the .net fix and that didn't work for me. I started up autocad went to options and profiles and exported out my profile (in case something goes wrong). Then went to programs and features in Windows 7 selected Autocad 2011, selected uninstall/change (up top see it? yeah that's it!). Then selected repair. Once done my autocad profile was set as default, no biggy my current config was still in profile. I selected it and I'm back to where I was minus the exclimation point issue.
Problem solved! Now why didn't I do this 6 months ago?
Active Member
0 Kudos
Post 8 of 12
02-08-2013 01:29 PM in reply to: wizeguy
Thanks for the reply...I'll give it a try when I'm back in the office Monday.
299 Kudos
Post 9 of 12
02-08-2013 03:20 PM in reply to: wizeguy
Have you tried running 2013 since the repair of 2011?  I have similar issues at work and at home, and, if I recall, repairing the earlier version simply transferred the problem to the newer version; repairing that reverted it back to the earlier version.  But it has been a while since I tried that, so my memory may be slightly off.
David Koch
Active Contributor
1 Kudo
Post 10 of 12
02-08-2013 03:28 PM in reply to: David_W._Koch
Well great, David do you not like happyness or something? I was so happy that I finally fixed my issue now this! :smileyhappy:
Ok Ok mister party pooper. I just closed 2011 with no problems. Fired up 2013 opened a drawing shut it down and all looks good. Ok fired up 2011 again opened a drawing up shut it down and everything looks fine.
Phew! Its 3:30 on Friday and I will not let you ruin my weekend. No sir I won't. It looks all clear here. Thanks for making me all worried. :smileyhappy:
