Hi, I am new to Structure so please bear with me. I have downloaded & installed the Extensions. I am trying to add a baseplate to the bottom of an HSS column but I get the message ' column selection is incorrect' I try to select the bottom of the column but the entire column is selected. I can get it to work on a W column but that's not what I need. Any suggestions, thank you in advance.
