Hi Amigos:
The botttom of the bar of the screen where you comunicate commands like area, line, etc disappear for example when I try to get the area of an square I can't see the result because that bar is not there any more.
Please help if I don't complete this project soon I will get slaughter and will be your fault 😄 and offcourse I will look for you in halloween.
Thanks.
Solved by David_W_Koch. Go to Solution.
