There is a file that gets overwritten with the new version. Lets just work
with ACA2008 and ACA2009, forget ACA2010. Let me ask this, if I'm running
ACA2008 and put on ACA2009 and find out that it won't work correctly, like
Pedro Aroso found out with 2009, and uninstall 2009, will ACA2008 still run
correctly? I thought that there was a file that had to be backed up to
replace the one that referenced ACA2009, otherwise, you have to do a full
reinstall of ACA2008. I don't want to do that since I'd loose my
customization.
Nick
"Nick Haury" wrote in message
news:6323213@discussion.autodesk.com...
> What is the file that needs to backed up so if you run ACA2010 side by
> side
> with ACA2009 and have a problem then I can uninstall ACA2010 restore the
> backup file and ACA 2009 will still work without reinstalling it?
> TIA
> Nick
