I would like to have just one glass pane per window unit.
They insist on looking like double hung windows.
Solved by TexShalter. Go to Solution.
Thanks Mary,
still no luck ...
I deleted all the old "double" awings in my drawing, purged drawing, closed aca. Re-started ACA & went into the contend browser, added the single awning (like you pointed out) but my drawing insists on adding a horizontal bar in the middle. Doesn't match the little icon in content browser.
very odd.
I wouldn't care so much, but it messes up the schdule if I just make them pictures or casements in the model.
It sounds like the style was edited somehow. Check the Awning window style and verify if it has these settings:
Also verify if the style has any muntin Blocks.
FYI adding an existing window (that has been altered) will not change the definition even if added from the browser or a tool pallete however you can right click on a tool in a pallete and select redefine and it will change the in drawing def to match the tool.
