AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Awning windows insist on muntins
5 REPLIES 5
TexShalter
844 Views, 5 Replies
I would like to have just one glass pane per window unit.
They insist on looking like double hung windows.
5 REPLIES 5
MarySeufert
in reply to: TexShalter
A different style perhaps...
EXPERT ELITE MEMBER
TexShalter
Thanks Mary,
still no luck ...
I deleted all the old "double" awings in my drawing, purged drawing, closed aca. Re-started ACA & went into the contend browser, added the single awning (like you pointed out) but my drawing insists on adding a horizontal bar in the middle. Doesn't match the little icon in content browser.
very odd.
I wouldn't care so much, but it messes up the schdule if I just make them pictures or casements in the model.
MarySeufert
It sounds like the style was edited somehow. Check the Awning window style and verify if it has these settings:
Also verify if the style has any muntin Blocks.
EXPERT ELITE MEMBER
TexShalter
in reply to: MarySeufert
That was it - Thanks Mary
ntellery
FYI adding an existing window (that has been altered) will not change the definition even if added from the browser or a tool pallete however you can right click on a tool in a pallete and select redefine and it will change the in drawing def to match the tool.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
”Boost
