AutoCAD Architecture General Discussion
Active Member
JayHultman
Message 1 of 3 (496 Views)
Autodesk 360
496 Views, 2 Replies
04-25-2012 10:34 AM
ACA2013 - Anybody else having an issue with program and computer freezing when signed into Autodesk 360?  ADsync.exe seems to be using all the computer's virtual memory.
*Expert Elite*
pendean
Message 2 of 3 (470 Views)
Re: Autodesk 360
04-26-2012 05:58 AM in reply to: JayHultman
I suggest you turn off 360 unless you are actively using it: or at least turn off some of the many SYNC options that you probably don't use.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
austech_structural
Message 3 of 3 (373 Views)
Re: Autodesk 360
05-27-2012 06:31 AM in reply to: JayHultman
Adsync.exe which is associated with Autocad 360 caused my computer to blue screen and memory dump.
Turned Autocad 360 off and have not had a problem since. Was not even using autocad at the time.
Will not use 360 again and I am trying to find out how to uninstall this rubbish program.
And as for the previous post, what nonesence, if something blue screens a computer their is a significant problem with the program which needs to be addressed and not bury your head in the sand by turning it off.
Post to the Community
New Post
Need installation help?
