AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Autodesk 360
2 REPLIES 2
JayHultman
735 Views, 2 Replies
Autodesk 360
ACA2013 - Anybody else having an issue with program and computer freezing when signed into Autodesk 360?  ADsync.exe seems to be using all the computer's virtual memory.
2 REPLIES 2
pendean
in reply to: JayHultman
I suggest you turn off 360 unless you are actively using it: or at least turn off some of the many SYNC options that you probably don't use.
Adsync.exe which is associated with Autocad 360 caused my computer to blue screen and memory dump.
Turned Autocad 360 off and have not had a problem since. Was not even using autocad at the time.
Will not use 360 again and I am trying to find out how to uninstall this rubbish program.
And as for the previous post, what nonesence, if something blue screens a computer their is a significant problem with the program which needs to be addressed and not bury your head in the sand by turning it off.
”Boost
