AutoCAD Architecture General Discussion
Valued Contributor
cnewton
Message 11 of 17 (320 Views)
Re: Autocomplete on the command line, list box cut off by screen.
11-07-2011 08:54 AM in reply to: niranjan.kamath
I think we may have a language barrier here. In your screen shot image, you refer the Main Monitor ( 1 ) as not identifying the space in this setting. By space are you referring to the command line? I am not certain of what you mean when you say "space".  You say that the main monitor identify space below, I assume by this you mean that the screen resolution of monitor (2) is less than that of monitor (1). I thought that you were referring to the command list appearing below the command line on the monitor. I am attaching screen shots of how the monitors are arranged and their settings. What should I be setting the second screen resolution to in order to solve the issue?
Clint Newton III
Project Manager
Spillman Farmer Architects
MarySeufert
Message 12 of 17 (310 Views)
11-07-2011 09:29 AM in reply to: cnewton
It looks like the secondary monitor needs to have a 'Y' resolution less than the 'Y' resolution of your primary monitor. Since you are using your secondary monitor in portrait mode, its 'Y' is larger than the primary monitor.
You have a few options:
1. Dumb down your secondary monitor to a resolution where the 'Y' aspect of 1680 is less than or equal to 1200.
2. Change your secondary monitor to landscape mode.
3. Keep your current setup, but move your command line.
~ Mary
p.s. I too could never go back to life without dual monitors! Definately not an option.:smileyhappy:
_______________________________________________________________________
Normal people believe that if it ain't broke, don't fix it.
Software Engineers believe that if it ain't broke, it doesn't have enough features yet.
Valued Contributor
cnewton
Message 13 of 17 (305 Views)
11-07-2011 11:14 AM in reply to: MarySeufert
Thanks Mary,
I tried making the Y value for Monitor (2) less than the Y of Monitor (1), but alas that does not do it. :smileysad:
It also makes MonItor (2) less than readable.
I changed monitor (2) to landscape mode and yes, that does make the list behave correctly. Regrettably it defeats the purpose of having a portrait mode monitor with a landscape monitor. I can no longer view reference documents in portrait mode as a single document, unless I get better glasses and sit closer. It also means that it moves the second monitor to a head turn instead of a side glance.
 I am resigned to living with this as it is.
It is after all, a minor inconvenience as compared to some of the other issues I could be having.
Thanks for your input, it makes it easier now to accept my fate.
Clint
Clint Newton III
Project Manager
MarySeufert
Message 14 of 17 (298 Views)
11-07-2011 11:45 AM in reply to: cnewton
Hi Clint,
Figured it would probably make your secondary screen hard to read. :smileysad:
One thing I didn't think about before, have you tried making your left screen the primary monitor? This might trick AutoCAD into not registering the "blank space" between the two screen resolutions.
~ Mary
Valued Contributor
cnewton
Message 15 of 17 (296 Views)
11-07-2011 11:52 AM in reply to: MarySeufert
Brilliant thought!:smileysurprised:, alas Autocadd is not so easily fooled.
Also places task bar on secondary, etc.
But I am willing to try other ideas!
Clint Newton III
Project Manager
Product Support
niranjan.kamath
Message 16 of 17 (286 Views)
11-07-2011 07:15 PM in reply to: cnewton
I have seen the screen shot of your settings and I believe the issue at your end could be resolved by aligning the monitors as shown in this attached image.
Align in such a way that the bottom of both the screens matches and is on same level (see attached). You may retain the both monitor resolution as it is. Just drag your primary monitor down or move the secondary monitor up to align the base level. This should resolve the issue.
We just need to base level of each monitor to match.
Apologize for any confusion in my previous thread.
Niranjan Kamath
Valued Contributor
cnewton
Message 17 of 17 (280 Views)
11-08-2011 07:29 AM in reply to: niranjan.kamath
Sorry but that does not work. I tried to the left, to the right, above, and below. The only thing I have found to work is to use only one monitor and as I previously stated, that is not an option. So I have to simply accept that this feature does not work for my apparatus and move on. I have already spent too much time in search of a solution.
Clint Newton III
Project Manager
