Every single time I open a new window the new window size is always "not maximized" let me show you what I mean.
This is the way I want my new window to open all the time.
Why doesnt the maximized window size stick?
What setting do I need to toggle to make this work?
I may remember that this was an issue versions ago. It came down to the condition when you closed ACA. If you close with a drawing maximised via close acad, and then it asks you do you want to save (unless you just saved), then when you open again it will be maximised. If you close acad when all drawings are closed down you will have this problem. It's possibly a setting is not updated unless you close acad with a drawing open & maximised
Not sure I have it correct but it may be the same issue.
