I received a drawing of an os map which is in inches but when you measure between 2 points it is in metres.
I have tried to change the units to mm and the scale to 1:1 but the drawing does not appear to change to mm although in the drawing units box it states mm, and the scale box states 1/64 = 1-0.
When the drawing set up box appears i have ensured the Scale model space objects in current drawing to reflect new units is ticked. But this totally throws the dimensions out and the grid co-ordinates do not correspond with the OS map
Anyone have any suggestions?
Thanks Carl
