I'm running Autocad Architecture 2013 on a Inspiron 15 7000 series:
-Windows 8.1
Intel Core i7-4510u CPU @ 2.0 GHz
-8.0 GB memory
-64 bit operating system
I have a 80 MB file with lots of walls, doors, windows, and trees. When I publish, it takes about 40 minutes to create 5 pages (2 pages plans, 2 pages with 4 elevation viewports, 1 page with 1 perspective view). If I open task manager when publishing, I've noticed the "Memory" and "Disk" max out (or stay close to maxing out.)
Autocad also runs pretty slowly in general, especially with the trees unfrozen.
I'm not up to speed when it comes to computer hardware. Is this something I can fix by adding/replacing hardware? Is this something I might help by using an external hard drive to store files? Is this something that will remain a problem as long as I'm on this laptop?
I appreaciate any help.
Make sure to purge (-Purge from the command line) anything you don't need, in particular, REGAPPS. Also run a recover to remove any possible errors. I would also test the size of a drawing with just the trees. You might also try inserting your drawing into a new drawing (insert with explode checked and specifiy origin unchecked), and see if the new drawing size is smaller.
