AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AutoCAD Architecture 2015 Lisp not working
2 REPLIES 2
twallacemagee
1190 Views, 2 Replies
I have the following lisp that has worked fine on all versions prior to 2015, can anyone tell me why it won't work now and what I would need to modify to get it to work.
(defun c:gl (/ LAYER)
(setq LAYER
     (cdr
          (assoc 8
               (entget
                    (car
                         (entsel "Pick item for new layer "
(command "-LAYER" "SET" layer "")
(setq onck 0)
2 REPLIES 2
I do not have ACA 2015 available to test your code, but I do not see any reason why it would not work in 2015.
You could just use the LAYMCUR command, which does the same thing.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
pendean
in reply to: twallacemagee
... Or the even older _AI_MOLC command which did the same thing as that lisp.
”Boost
