Hey, I'm very new to AutoCAD Architecture 2011 and some how I lost/deleted/closed my main tools on top of the page ( Home, insert,annotate,render,view,manage). I'm really desperate to continue my project that I started, but I can't find a way to return those main tools. Can some one please help me? I would really appreciate it 🙂
Regards, Daniel.
YES IT DOES RETURN!! 🙂 thank you so much for your help! I just have one more equestion,sir. How would i move the ribbon back to the to of the page? because it appeared in the middle of my page.
Kind regards, Daniel
You should be able to drag the ribbon palette up toward the top of the ACA window and it should dock.
If you can not move the palette, left-click on the lock icon on the Application Status Bar (at the lower right of the ACA window) - if there is a check mark next to Floating Windows in the popup menu, select it to clear the check mark and unlock Floating Windows.
If the ribbon palette will not dock, right click on the palette title bar and, in the contextual menu that appears, click on Allow Docking, to place a check mark in front of that menu item and allow the palette to be docked. Now when you move the ribbon to the top of the ACA window and it should dock.
(If you unlocked floating windows, you may want to re-lock them now that the ribbon is docked, if you want to keep other floating windows (palettes) from moving.)
it works perfectly! thanks, again for you help, David! i will deff return to this discussion group when i have any other issues!
Regards, Daniel
