When trying to cut a section in ADT 2012 I get the following message:
Command: _AecVerticalSection
Command not allowed because drawing contains objects from a newer version of
this application.
How can i get ADT 2012 to cut the section i need?
Thank You
Kevin Cardani
Solved by kcardani. Go to Solution.
Solved by pendean. Go to Solution.
