Hi there, I'm trying to figure out something. I have the Building Design Suite 2015 standard and I saw that in the Autocad 2013 Architecture you were avle to design 3D walls, doors ect.... can I do that with mine? I thought that my Suite was including Atuocad Architecture
Solved by Kiko-ita. Go to Solution.
The 2015 edition of the Building Design Suite Standard includes AutoCAD, AutoCAD Architecture, AutoCAD MEP, AutoCAD Structural Detailing, Showcase, AutoCAD Raster Design and ReCap. As Nathan mentioned, if you only installed AutoCAD, you will not have the features of AutoCAD Architecture, which is a separate installation.
Thanks for the replies!!!
I got it!!! I did a basic installation without selecting the Architecture. The problem now is that when I start the installation is failing. I already tried twice and I saw that at one point it's saying that there is a new version so I tryed to do the update but I got an Error 1618 ( I google it and is because I'm doing 2 installations at once).
I will try again later now I need to work 😉
