I am teaching a course using AutoCAD and my student's using AutoCAD Architecure are having problems loading the Expresstools. When they try to load them through the control panel/uninstall change/add or remove features the only options that come up are a list of language options.
I am suspicious that they have erased the executable from their machines (C:\Autodesk). Is this the possible issue?
Thanks for any answers.
Marla
I'm surprised you haven't received a reply after a week. At the command prompt in a drawing, have you tried loading the application using APPLOAD then browsing to EXPRESS TOOLS? If you have and it wasn't successful then you may be correct about an incomplete installation or deleted support files because ET doesn't load automatically during initial program installation. Good luck.
