I have an HP workstation Z220 with OS Windows 7 64 bit. I have installed my printer HP Laserjet Pro CM1415nf using the original CD Drivers and have also installed AutoCAD Architecture 2011 and 2013.
When trying to print from both AutoCAD versions to the printer, the application crashes and I need to close the program. When I try to print to a different printer everything is ok. I have checked for updated drivers of the printer and downloaded from HP site by the problem is still there.
What should I do?
Solved by pendean. Go to Solution.
Go to HP's website and download/install the HP Universal Printer Driver: seems to cure Win7 64bit problems for most AutoCAD users.
