I'm working on a school project that requires me to use X References from a source file. As of right now I'm almost done with the project, however I need to print each floor plan to scale in a title block. I have X referenced the title block into paper space and added a view port to show the floor plan within the title block. At this point everything looks great and ready to print.
Here is the issue.
I try to export the file as a PDF to print on a 11x17 sheet of paper however, when I open up the PDF file, nothing shows up except a couple random layers on my file and the title block.
Note: I can not directly print from paper space on AutoCAD because our computers will freeze. We HAVE to export it as a PDF...
