Hi fellas...I'm getting the same problem. Could it be that there is too much data in one program? Because I am working with all my drawings in one file. I have my Site Plan, Elevations, Floor Plans, and Sections all on one file.
I believe acad has grown to such a size that running it on a 32bit OS where it can only access 2Gb of RAM is no longer an option. If you don't have plans to upgrade to 64bit with at least 8Gb of RAM, then may I suggest you've reached the limit of acad upgrades. This 400lb gorilla of a program needs feeding and 'home' level computers don't seem to cope any more.
Thank-you to everyone who has replied to my question. It is very frustrating to have to deal with this. The program costs a lot of money, and we should not have to deal with this. But unfortunately we have this community to rely on, and I appreciate every word believe me..As of late last night, my computer just shut down, causing me to lose an hours worth of hard work. A window popped up stating that I had a FATAL ERROR: And it said " Unhandled Access Violation Reading 0x08db Exception at 62Of1ff4h. I do not understand this message, but I do know that it cannot be good either..Once again thank-you for the replies and thank-you in advance to anyone with further comments. I will definitely keep in touch for further reviews.
Darcy6778
The problem is that on the latest versions of AutoCAD (2009 and above) when you close a file down but not the entire AutoCAD program AutoCAD doesn't always return the memory it used back to windows system control. So when it goes to do something else it doesn't use that free memory and so it slowly runs out of system memory. Other than upgrading to a VERY VERY BIG amount of memory, the only quick solution is to completely shut AutoCAD down which does then return all the AutoCAD memory back to the windows system.
I have the same problem on 6 computers with ACA 2011. We have 5 that are on 32 bit XP w/ 2 GB of ram and 1 that is 32 bit windows 7 w/ 4 GB of ram. We have done the close down at lunch and dinner, but it seems about after 4 hours, we get the error. the cad file is about 12 mb, so not to big. We had just upgraded a month ago from 2008 to 2011. In 2008, we could have 5 cad files open and no problem. Now we have issues with 1 open.
For all that money for the software you think it would fix a problem that has been around since 2009 version.
Does the unlimited undo have an issue with this and can we limited the number of undos?
