<johnbalasundaram> wrote in messageI
href="news:6200497@discussion.autodesk.com">news:6200497@discussion.autodesk.com...
am using Autocad 2010. I am using HP workstation 4600. The system
configuration are as follows: Intel(R) Core(TM)2 Duo CPu E7400 @2.53Ghz
2.53GHz, 4.0 GB RAM, 64bit Operating system (Windows Vista Business) The
problem is that I am getting the error "Autocad is running out of system
memory.Continuing the current command may result in program failure or loss of
data. Do you want to cancel the current command?
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px"
dir=ltr>
"Nathan" <
title="mailto:nospam@nospam.net CTRL + Clique para seguir a hiperligação"
href="mailto:nospam@...> escreveu na mensagem
title="news:6200484@discussion.autodesk.com CTRL + Clique para seguir a hiperligação"
href="ne......
seems to be a common problem. Not letting
go of memory. seems to occur after a time and having other applications going
as well.
try restarting.
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
title="news:6200497@discussion.autodesk.com CTRL + Clique para seguir a hiperligação"
href......
of data. Do you want to cancel the current command?
<johnbalasundaram> wrote in messageDo
href="news:6201502@discussion.autodesk.com">news:6201502@discussion.autodesk.com...
we need to restart everytime. All the work which is done is getting lost.
Please help me to fix the same.
dir=ltr>
"Nathan" <
title="news:6201552@discussion.autod CTRL + Clique para seguir a hiperligação"
href="news:6201...
esk.com...
How much do you loose cancelling the current
command??
Just cancel, save and restart. ok not a
great solution but it's all you got until they work the memory thing out
better.
title="news:6201502@discussion.autodesk.com CTRL + Clique para seguir a hiperligação"
href......
"Pedro Aroso" <
href="mailto:pedroaroso@clix.pt">pedroaroso@clix.pt> wrote in message
href="news:6201785@discussion.autodesk.com">news:6201785@discussion.autodesk.com...
Nathan,
When you receive the message, it's too late,
because you can not save the drawing or use any command anymore.
"Nathan" <
href="mailto:nos...> escreveu na
mensagem
href="news:...
esk.com...
command??
better.
same.
