AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AutoCAD 2008 on 64 bit windows
5 REPLIES 5
849 Views, 5 Replies
I just purchased a new computer. I am familliar with autocad 2008. I tried to download 08 on my new computer which is a 64 vit version of windows and it said autocad 2008 does not support 64 bit. Is there anyway i could get autoCAD 2008 on a 64bit version of windows?
Thanks.
5 REPLIES 5
If you use the original install disc, it has the installation for both 32
and 64 bit.
Any other way and you're probably not getting the full install.
well i only have the student version. I am only 17 and cannot afford to buy the full product.
You downloaded the 32bit it would appear: your error message would read as
you see it.
Dean Saadallah
http://LTisACAD.blogspot.com
vanderloo5
I had to do a semi-complicated work around to make mine work. I am on xp pro 64. It involved downloading a program, (orca), that enables you to change the programming a bit to make it work. I wish I could help you more but it's been awhile since I did it. Hopefully someone will see this post and be able to guide you through it. Or maybe do a search in the discussion groups on Orca and see what comes up. Good luck.
Phil
See if this helps.
http://discussion.autodesk.com/forums/thread.jspa?messageID=5929919
http://www.technipages.com/download-orca-msi-editor.html
Evan
wrote in message
news:6045591@discussion.autodesk.com...
Orca and see what comes up. Good luck. Phil
”Boost
