I guess you know that it's corrupted content being sent to the sin bin.
If you are only using Autocad, maybe ACA using the autocad only option and
take out the ACA portion that may be the cause of it. When you install you
have the option of creating an AC only version which doesn't load the extra
aec items as this may make your drawing a little uncompatible with AC users
(consultants). However you may miss some of the great ACAD tools in ACA.
To be honest it sounds like some hardware issue (memory?) is failing and
causing corruption because what you describe is not normal behaviour. Can
you record which jobs are being touched by who and tnote who has worked on
the corrupted drawing? Are they stored on a server? Refediting can cause
cleanups to go wild but you are not using aec.
wrote in message
news:6276629@discussion.autodesk.com...
I have been having many issues lately with the creatin of new layers in my
drawings named like this AUDIT_D_090408113943-44
The layer will be created in addition, for example, to the A-WALL layer but
will take all of the A-WALL linework and put it onto the new Audit layer.
Sometimes it will create many of these files and also take on layers in
dynamic blocks which are very difficult to fix. Often it will change all of
the layer colors to one color which is not in our standard.
I don't know why these layers are created but for some reason I feel it
might be caused by refediting xref's.
I usually have to fix all of the layers I can, delete and replace blcoks if
I cannot get rid of the layer though WBLOCK or AECTOACAD.
It would be wonderful to know what is cauing this to happen so that I can
advise my team to not use certain practices.
Thanks for your advice.
We are on AutoCAD Architecture 2009 but strictly doing 2D drawing. (Also
having scaling issues between metric and imperial . . . but that's another
issue.)
