AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Array dialog box elimination
2 REPLIES 2
348 Views, 2 Replies
Is there a way to eliminate the array dialog box and revert back to entering
array values on the command line?
2 REPLIES 2
Type in "-array" (with dash) at the command line. You should be able to redefine the command on the toolbar button also.
I did this for awhile because I did not like the dialog box either, but now I am used to it.
Dianne
for some reason my array coomand does'nt open (no window) i only have the command at the bottom. Is there a way to fix that. Please I' m new on autocad and this is stopping my learning.
Mike
”Boost
