I am an interior designer and layout my drawings using interior wall dimensions vs exterior wall dimensions. When I am drawing walls in plan view and I justify the wall either left or right the walls when drawn at 90 degrees do not join there is void open space in the corners. Could you confirm if there is a wall setting that I could change to allow me to draw walls that automatcially join following the interior wall dimensions? Thank you
