AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Architectural 10 Problems
2 REPLIES 2
MaggieYork3626
232 Views, 2 Replies
I have set up my Quick Access Toolbar on a weekly basis because it keeps disappearing.  I have followed all of the directions of going to the user interface area, updating the new toolbar name that I created, have chosen it to run as the default, have customized the work space, clicked done, apply and okay, and it remains there for about a week and then disappears.  When I open the user interface menu selection the name I created is still there but none of the commands I have chosen are there.  I also keep having AutoCAD closing down because of some error it has encountered.  I updated from 2007 when I got this new laptop.  I'm having so many problems I wish I had stayed with 2007!  Any help would be greatly appreciated!
2 REPLIES 2
pendean
in reply to: MaggieYork3626
What is schedule to occur on your PC, or through your network to your PC, once a week?
Also, from your list, it appears you are not manually saving your final changes to your preferred WORKSPACE once you exit CUI command: WSSAVE is the command, select your desired workspace and click OK.
MaggieYork3626
in reply to: pendean
There is no rhyme or reason as to when it occurs.  I have a scheduled weekly security program that runs on Tuesdays at noon, but it does not coincide with this.  It's just a random occurrence.  Thanks for the WSSAVE...I didn't know about that and will try it now.  Thanks for your help!
”Boost
