How do I load my .xtp hatch file from Arch 2008 into my Arch 2011 tool pallet?
Solved by pendean. Go to Solution.
Open toolpalettes, then drag and drop the file from it's central location to your open TP in your open DWG file.
Remember, TPs are just pointers, they contain no DWG files, they just point AutoCAD to where to get the file. So it's not enough to just move the pointer usually.
I have tried to drag the .xtp from its folder onto the open tool pallet and windows won't allow the drop.
i HAVE ADDED THE FILE LOCATION IN BOTH THE SUPPORT FILE SEARCH PATH AND THE TOOL PALLET FILE LOCATION. PLEASE ADVISE.
Thank you for your time.I use the hatch tool pallet extensively, so it is very important to me.
I find no "import" function with the tool pallet, maybe that is the help I need.
In fact I don't see how to add a single hatch to the pallet, if anyone can help with this.
Can anyone else post to this question.
Since you are using ACA, and not plain AutoCAD, explore this old topic:
Maybe Autodesk has chosen to not support this function or maybe there is another very, very fast hatching tool. Anyone?
There is no hatches TP in ACA2011 (just like ACA2008), but there is one in ACA 2001's RUN AS AUTOCAD profile (just like ACA2008).
Did you forget to install that profile? See attached screenshot for installation: the other two from ACA2008 and ACA2008 run as AutoCAD.
OPTIONS command>Profiles Tab>... do you have an AUTOCAD only profile? It needs to be active. If no such animal exists, you need to rerun the installation, go into Custom Install, and select it (see my last post, first screenshot).
I suspect that is how you ran ACA2008, and need to run ACA2011. See attached.
Dean, thanks. I have some reading to do. I have been running ACAD since rev 12 on a Mac. I am totally unfamiliar with profiles (other than my own), let alone understand your posts... It's been years since 2008 and I quite frankly don't remember loading the hatches the first time. To update the pallet I just copied one of the hatches, pasted it, and then changed the properties.
I started by using my 2008 profile, if we are talking the same profiles, and then I have since changed it, but it never allowed the tool pallets to accept the drag and drop of the hatch .xtp file.
My email is fbirch@hughes.net. If you have time would you send me your post ideas with a little more detail?
Thanks again
Fred
Post a screenshot of the PROFILES tab in OPTIONS command in your ACA2011 please.
