AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Applying materials to AEC Polygons
4 REPLIES 4
drew_almighty
349 Views, 4 Replies
I want to apply a material to AEC Polygons in order to bring them into Max and select by material. I've tried digging into the AEC Polygon styles, but don't see a material tab like I do with mass elements. Is this possible?
4 REPLIES 4
in reply to: drew_almighty
You used to be able to apply materials to pen assignments (1-255). You could then create AECpolygon styles with a solid infill using the appropriate pen number. You can no longer do that in 2007-2009, but you can apply materials to individual objects.
"but you can apply materials to individual objects"
What does this mean? I can't find a way to apply a material to AEC polygons, even individually.
second button from the right, then select the object.
Those materials don't make it across the file link to Max.
”Boost
