When I insert a wall tag I find that the wall tag text and the box is too large compared to my annotative text. For my annotative text I use a 5/64" height in paper space. When you take a look at the attached picture you can see that the W1 from the wall tag is much bigger than my W1 annotative text object. It is my common practice to make all text the same size on my pages.
Has autocad made an easy tool for me to adjust the wall tag size? Or do I need to go into the "AEC6_Wall_Tag-P" block, and edit that block by hand?
I find that I have the same text height problems with the annotative titles, and sections. I have also included a comparison of 5/64" text right beside a title callout.
Has anyone else noticed this problem with their annotative text?
If there is not an easy way to change this, then I need to change the blocks, which means I would have to edit the blocks in every single new release of ACA that I receive.
Solved by Gary_J_Orr. Go to Solution.
If I am understanding your problem correctly -- You are using OOTB (out of the box) autodesk blocks for your drawings.
When you upgraded from 2014 -> 2015 the changes you made to your OOTB blocks did not happen in 2015.
This is the correct behavior. If you modify the OOTB blocks you should save them somewhere for your use and you should insert them from where you saved them instead of the default autodesk location. You should be able to open an older file you have and saved the blocks out with the "Wblock" command. Then you can redefine the block in your new drawings that have the wrong text size.
you will probably have to use the block attribute manager (Battman) afterwards to sync them.
Did I understand your problem correctly?
I believe that you did understand my problem correctly, your response makes sense.
I was hoping that there would be an easier way to adjust the OOTB annotative block sizes, without modifying the blocks in every release.
After watching many videos on AU about setting up templates, I have adopted the idea that everything should be left as OOTB as possible.
