I've come across a drawing at work that contains annotative scales that we use all the time for referencing (ie callouts, text, etc.) The problem I'm running into is when this dwg is X-Reffed into any other dwg and you switch the annotative scaling in paperspace or model space to anything other than 1:100 it just hangs and won't let you do anything else.
I decided to try this at home on my PC which has ample performance (far greater than my work's pc's) and even it just ends up hanging and results in having to CTRL+ALT+DEL out of it. I've also tried saving everying as new dwg's, purging, auditing and nothing. Has anyone else run into this problem and if so how do you solve this without having to redraw your entire dwg from scratch? Your help would be most appreciative as I've run out of ideas. We currently use AutoCAD Architecture 2009 at work but I'm running 2010 at home, not sure if this is of any help in figuring this out.
Sincerely,
David W.
