I´m having problem with annotative multileaders. They work fine while I´dont move the lead point. Once I change it, the annotative scale works just on the scale that I use to transform it. In any other scale, it returns to its original position.
Can anybody help me with this?
I'm leaving a picture of the problem.
Nicolás
That is "by design". Since the size of annotative content changes with different scales, you may need to adjust the position of each scale to get the drawing to read. You can synchronize the positions of all scales, if you want. Set the current drawing scale to the scale that has the configuration you want for all scales, select the annotative content, right click and choose Annotative Object Scale > Synchronize Multiple-scale Positions from the context menu. See attached image. (Or you can type ANNORESET at the Command: prompt to run the command.)
Thnxs,
It works just fine, but only with one multileader, is there a way to sincrinyze multiple elements?
Nicolas
