I've been requested to revise a BOMA plan done in ACA08.
The room name of a particular space is too wide and the client wants the room name stacked (see attached .PDF).
Can this tag be edited to do so?
Scott
The ability to set an attribute width and then have it wrap if wider was added to AutoCAD blocks in the 2008 release, but it did not make it into Multi-View Blocks until the 2009 release of ACA. You could set up a tag with multiple atttributes and display part of the room name in each.
