Is there a method to generat AecPolyGons automatically, like you can Spaces?
If so, how?
Solved by David_W_Koch. Go to Solution.
Can't generate those automatically as far as I know.
You can convert closed polylines to AecPolygons.
Not sure how you want to want to use AecPolygons, so it's difficult to offer suggestions.
@leothebuilder wrote:Can't generate those automatically as far as I know.
...and you can use BPOLY to generate the closed polylines, provided you can isolate the bounding geometry. If that geometry includes Walls with openings (Doors, Windows, Door/Window Assemblies, Openings), you may have to temporarily adjust the cut plane to a level that does not cut any openings.
Yes, I am familiar with all these methods.
I did find that you can make Spaces that are only 2d... since spaces go in somewhat easier than BPoly, I've chosen to use Spaces instead.
As far as how I am using them... we are a multi-discipline MEP Contractor... the Spaces in our case, right now at least will serve only for Room Name info. We have our own tags. With MvBlocks we can have two display representations that will provide a placement for HVAC and a separate placement for Plumbing and Piping both reading the same data.
We may use the spaces also for gbxml export purposes.
At any rate, thanks for the confirmation!
