We have 20 brand new workstations that are running Architecture 2011 and it's extremely slow to change visual styles, regen, and 3d orbit. Here is what we are running.
HP Z400 Workstation
Intel Xeon quad @ 3.07
6gb Installed ddr3
Windows 7 64 Pro
NVIDIA Quadro 4000 with latest driver updates
I tried to install the Nvidia autocad performance driver and got the message "No application found for which a performance driver can be installed or upgraded."
Any Ideas, please help...
Charlie
We are experiencing the same problem with the latest workstations:
Dell T5500
Dual Six Core Processors 2.93GHz
24GB RAM
Windows 7 64 Pro
2 x 146GB hard drives
NVIDIA Quadro FX 4800
We tried Autodesk certified driver, the latest nVidia driver and the Performance Driver for AutoCAD 2011 with no luck !!!
The crazy thing is that we can 3d orbit the same model without problem on older workstations !!!
Waiting to hear back from Autodesk.
I have the same problem with HP 8760 Workstation, Quadro3000m.
Could you learn anything how to solve it?
Thanks.
just something to try. Turn off the cube and place the View toolbar back on you desktop. Use the toolbars to set shademode. I have a Dell T7500 with dual quad core xeon processors and 6gb ram and I was having the same problem. With the cube it was taking about 1-2 minutes to switch view direction and switch between layout and model space. After turning off the view cube and adding the toolbars back in it went to about 2-3 seconds.
Hope this helps.
Joe
I shall be Pedro for a bit... Autodesk doesnt care or know why... We have had this issue for a while now... Quad Core 16GB ram should not be this slow... Sketchup flows better than this does...
We found that this issue happens when the application shortcut has Compatability option to run as different operating system, e.g. Windows Vista on Windows 7.
No no... It's not it. I'm not in compatibility mode but still too slow. God **** Autocad. But 3dsMAX is fine. No problem.
No idea if anyone is still having this problem or not.....but i stumbled upon theisthread when looking for a solution to the same problem.
i seemed to find a workaround..
I was playing around with the settings to try and improve the performance and accidentally turned off the hardware accel. the model then responded much quicker. I thought this was very strange so i turned the accelleration back on again and now the model orbits and pans with very little lag.
no idea why but turning the acceleration off then back on again seemed to work for me.
obviously may not work on all systems but its weel worth a try.
