I have a dwg fie that I have created using ACA 2015 and it was fine when I save the file.
All of a sudden, whenever I try to open the file in ACA 2015 or AutoCAD 2015, the application crashes with a Fatal Error message.
I tried Recover but does not work as well.
The drawing file is attached, hope someone would look into it. Thanks.
Alex Su
Autodesk Autocad & Inventor 2012 Certified Pro
Autodesk Inventor 2012 Certified Instructor (ACI)
Autodesk Inventor 2012 Certification Evaluator (ACE)
