AutoCAD Architecture 2015 Service Pack 1 is now available.
And the bug with 2dSection /elevation is still there. When you edit linework and refresh it, all the line you have erased come back...
It's not noted in the fixed list but it appears work has been done to restore the WYSIWYG display in paperspace.
Items display black and not colour as they are supposed to.
Shrinkwrap hatching (ie. solid) now displays at the back of componants so as to not obscure the companant.
-- great job. Thanks.
However it appears there is still work to be done on displaying saturation correctly.
See attached drawing file and compare paperspace display with a print preview.
Hopefully it's easy to add it to the work you have just done.
Shrinkwrap still have some display problems in 2d Section/Elevation even after ACA 2015 service parck 2
I included an example. Only some of the shrinkwrap show up.
