All of our uesrs are getting slow performance while CTB is accessed from the network folder, from local folder the same CTB works fine.
Any body have solution to keep the CTB in netwok without affecting the performance ?
Biju
Check the other files in that folder. Are there any shortcuts that point to files or folders that do not exist? I have seen the Add-a-Plot Style Table Wizard shortcut (or, in the Plotters folder, the Add-A-Plotter Wizard shortcut) from previous versions get copied over when copying office-standard files from a previous release.
AutoCAD will try to resolve any shortcuts found, and there will be a delay waiting for the search to time out if there are shortcuts pointing to non-existant items.
