Hi everyone. Sorry if this is a repeat but I have been away from these forums since I retired a year ago but am trying to help out my old AutoCAD workers. In previous versions of ACA there was a "index.html" file located in the ACA help directory. The index.html file opened the AutoCAD Architectural Help page to gain access to the user guide, command references, customization guide and other things. I made a short cut to this file and placed it on everyone's desktop. They could use this without opening ACA or while in ACA. In ACA 2013 I can not find the index.html file. Does anyone know if this exists or if there is another file to get the same results?
Thank you,
Mike Trevelino
The Help is online now. For the ACA 2013 Help, go here:
http://docs.autodesk.com/ARCHDESK/2013/ENU/index.html
You can install an offline version, but the online version will have the most up-to-date information.
Thank you David for that information. I did install the offline file. It looks like it installs inside of ACA, but am not too sure. I am looking for something that works outside of ACA as in the past. Any other suggestions would be greatly appreciated! My company would have to use the offline version as their computers do not access the internet, they are pretty much locked down from internet usage.
Receiving activation codes with past versions was always a challange. I had to submit everything online from a separate computer and install all the codes on each and every pc.
Mike Trevelino
Some good news. After installing the offline version, I went back into my computers directory tree. It seems that the offline version installed the help directory with the index.html file. I am able to open this file without opening ACA. I now am going to have my network people copy the entire directory to a share drive to see if anyone could open it. Thanks again David for the information on the offline version!
Mike Trevelino
