ACA 2012 is pausing/hanging after each command is entered. System is a Windows XP system with 4gb of ram. Has anyone run into this issue? Was not happening in ACA 2011 and is not happening on the 2012 Windows 7 stations.
Save your profile, then set the default profile as current. If it fixes it, it's probably something in the graphics options.
Well, the problem is solved, I used the "AutoCAD 2012 Performance Slowdown Hotfix" The fix doesn't say that it works with ACA 2012 but I tried it anyway and it solved the problem. There is no more lag and I can pan smoothly again.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17013122&linkID=9240698
Hei
I have the same problem with you, but i have service P1. And when i try to installe the Hotfix slowdown, they said that service p1 already have it. should i installe it again anyway?
Thanks alot
