When I launch the program ACA 2011 the interfaces are not shown properly i.e Home ribbon: Build, Transparency, inquiring, Section & elevation, Details, Panels are missing. Instead are shown Panels more related to Autocad itself. Same problem occurs with all other Ribbons. Worst than that Contextual Ribbon Tabs do not appear when I click on a wall.
Can someone help me?
Thank you
Solved by LanceEdwards13. Go to Solution.
You are right! Now, how can I set the customization pan from Acad.cuix to Aca.cui. Please tell me step by step. Thank you
It is actually a little easier to show you in a video than step by step. Attached is a quick video in the link of the items you should check to make sure ACA is pulling the right CUI.
http://screencast.com/t/ctwH8BcpBy
