Was a solution ever provided for this problem? I am using AutoCAD 2010.
Can't find a solution from any resource.
I'm using MEP 2009 and have the same problem. Does anyone know of a fix for this? Has anyone found a solution? Thanks.
I am having this issue too with AutoCAD Architecture 2010, except I don't see the OSNAPS in the dialogue box at all.. I attached a photo of what I am seeing so you can see for yourselves..
We use AutoCAD Architecture, 3D Map and Civil here at my work, all 2010, and Architecture is the only here that is having the OSNAP issue in Windows 7..
Here is what I did, kind of an easy work around. When AutoCAD Architecture is installed I wind up getting 2 different AutoCAD Icons on my desktop. One is AutoCAD Architecture (US Imperial) and the other is AutoCAD 2010 - English.. What I did was open the AutoCAD 2010 - English because the OSNAPS show up there. So you can then set your OSNAPS there and they do carry over to AutoCAD Architecture (US Imperial).... For me that was the easiest work around until Autodesk fixes it...
But if they've had this problem since 2009 release.. Don't hold your breath.. lol!!
