K. Schneider wrote:
> The button is mapped correctly. I tried it with the ADT.cui as my main and it worked fine. So I went through and deleted all keyboard shortcuts, shortcut menus, mouse buttons, legacy tablet menu & buttons, and the double click options. I then re-imported them from the ADT.cui that I tested, and it still won't work. None of the other SHIFT+RC shortcut menus work, they all return SETVAR as the last command.
Interesting. The *only* change you made was using the ADT.cui when you
tested that (no profile change)?
If so feel free to zip up your CUI and attach it to this message and I
will see what it does on my test machine (using 2008 correct?).
Also, did you start your customizations from the ADT.cui for your
"enterprise" setting or did you start from scratch (or perhaps custom.cui?)
David Kurtz
