Before posting what should resolve the issue, I need to say...Please, Please, Please report any issues like this to Autodesk. If you're on subscription, please e-mail them the issue. If you aren't on subscription, please talk to your reseller and have them report it. When I talked to Autodesk about this issue, they've only had this issue reported to them TWICE. I had two in one day and obviously there's more than cases than that out there. These groups are great for getting answers, but if there is an issue with the product, they need to be reported...not just discussed on the discussion groups. Okay, I'm going to step down from my soapbox now. 🙂
Hopefully this may help the situation a little. I had two people call into our support with this same issue, which I could not produce on my end. A call (for me being a reseller AE) into Autodesk produced a response of...
"...need to do a clean uninstall ACA and also uninstall .NET versions. Then, reinstall ACA and let it install the .NET. Also, if they used the Migration Assistant, do NOT use it again with the new install."
The clean uninstall and reinstall did the trick of fixing the Mtext disabling/graying out the Ribbon as long as the Migration of settings wasn't used. A new install on a separate computer worked out just fine as well, again without using the Migration. Also, if you install the .NET versions directly from Microsoft first, the installation should go much quicker.
Below are the steps given to me via Autodesk. (which were derived from - http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=9700956&linkID=9240657)
Use the steps below to uninstall ACA 2010 fully to allow for a full clean reinstall.
You may experience issues with AutoCAD® Architecture (formerly known as Architectural Desktop) or AutoCAD® MEP (formerly known as Building Systems) after failed installs or uninstalls of other Autodesk products.
In these cases, it is strongly recommended that you completely remove the product from the system, and then try to reinstall the product.
Important! You should back up any customized Autodesk files before you implement the following procedures - (Unless you are going to recreate the workspaces manually which we recommend.)
To completely remove the product from your system:
1. Log on as a member of the “Local Administrator” group and disable any antivirus or anti-spyware programs.
2. In the Control Panel, double-click Add or Remove Programs in Windows XP, or select Programs and Features in Windows Vista.
3. Select the product and click Remove.
Using Windows Explorer, browse to and delete the following folders:
For Products on Windows XP:
C:\Program Files\AutoCAD Architecture 2010
C:\Documents and Settings\USERNAME\Application Data\Autodesk\ACA 2010\
C:\Documents and Settings\ USERNAME \Local Settings\Application Data\Autodesk\ ACA 2010\
C:\Documents and Settings\USERNAME\My Documents\ACA 2010\
C:\ProgramData\Autodesk\ACA 2010\
For Products on Windows Vista:
C:\Program Files\ AutoCAD Architecture 2010
C:\Users\\AppData\Roaming\Autodesk\ACA 2010
To delete the registry keys and reinstall the product
1. Log on as member of the “Local Administrator” group and disable any antivirus or anti-spyware programs.
2. On the Start menu in Windows XP, click Run. On the Start menu in Windows Vista, use the Search box.
3. Enter regedit in the text box and click OK in Windows XP or press in Windows Vista to start the Registry Editor.
4. In the Registry Editor, locate the following keys and delete them:
o HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8004:409
o HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.0\ACAD-8004:409
5. Delete the files in the Local Administrator's C:\Documents and Settings\\Local Settings\Temp directory to make sure that cached files are not used during the reinstallation.
6. Visit http://windowsupdate.microsoft.com to make sure that your Windows computer has all of the current updates and patches. Install any updates and patches as needed.
7. Restart your computer.
8. Log on as a member of the Local Administrator group and disable any antivirus or anti-spyware programs.
9. Reinstall the product.
Warning! Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft provides critical information that you need to know about the registry in the Microsoft Knowledge Base at: http://support.microsoft.com/support.
Use the Microsoft Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined for your operating system in following Microsoft Knowledge Base related solution at: http://usa.autodesk.com/getdoc/id=TS66513. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
Dwane Lindsey
MasterGraphics Inc.
Sr. Application Engineer
