AutoCAD Architecture General Discussion
Product Support
MichaelBussiere2
Message 1 of 5 (1,968 Views)
Accepted Solution
3DConnexion Devices
1968 Views, 4 Replies
10-03-2012 09:37 AM
ACAD 2013 Device communication Issue:
Users see issues with the following;
  • Zoom speed varies in perspective view
  • Pivot point position is far from the model causing the model to go off the drawing area when rotated
  • High zoom out speed after zooming in a small area of the drawing
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Autodesk 3Dconnexion Hotfix
Download: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20605633&linkID=9240618
This hotfix corrects the following issues with 3Dconnexion devices:
Consult the readme file for installation instructions and more details on the primary issues resolved by this update. Be sure to install the correct hotfix (32-bit or 64-bit) for your software and operating system.
Note: Before applying this hotfix to your Autodesk product, youmust install service pack 1-below (or SP1.1 for AutoCAD and AutoCAD LT).
ACA2013 Update 1: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20556359&linkID=9240658
Product Support
MichaelBussiere2
Message 2 of 5 (1,965 Views)
Re: 3DConnexion Devices
10-03-2012 09:39 AM in reply to: MichaelBussiere2
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Active Member
stensq
Message 3 of 5 (1,936 Views)
10-05-2012 03:32 AM in reply to: MichaelBussiere2
Will this Hotfix work with Autocad Architecture 2012?
Product Support
MichaelBussiere2
Message 4 of 5 (1,930 Views)
10-05-2012 07:17 AM in reply to: MichaelBussiere2
This will work with the following products,
Applies to:
AutoCAD® 2013
AutoCAD® Architecture 2013
AutoCAD® Civil 3D® 2013
AutoCAD® Electrical 2013
AutoCAD LT® 2013
AutoCAD® Map 3D 2013
AutoCAD® Mechanical 2013
AutoCAD® MEP 2013
AutoCAD® P&ID 2013
AutoCAD® Plant 3D 2013
AutoCAD® Raster Design 2013
AutoCAD® Structural Detailing 2013
AutoCAD® Utility Design 2013
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Member
DGArch
Message 5 of 5 (319 Views)
05-20-2014 02:15 PM in reply to: MichaelBussiere2
Zoom is too fast in constrained orbit mode, and too slow in walk mode (AutoCad Architecture 2009) is there a fix for this, or has this issue been remedied in later versions?
On a separate (somewhat related) topic, I can't edit (very easily, if at all) 3D models while in perspective view- has this issue been remedied in a newer version of Architecture?
Need installation help?
