AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
3DConnexion Devices
4 REPLIES 4
MichaelBussiere2
2808 Views, 4 Replies
3DConnexion Devices
ACAD 2013 Device communication Issue:
Users see issues with the following;
  • Zoom speed varies in perspective view
  • Pivot point position is far from the model causing the model to go off the drawing area when rotated
  • High zoom out speed after zooming in a small area of the drawing
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
4 REPLIES 4
Autodesk 3Dconnexion Hotfix
Download: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20605633&linkID=9240618
This hotfix corrects the following issues with 3Dconnexion devices:
Consult the readme file for installation instructions and more details on the primary issues resolved by this update. Be sure to install the correct hotfix (32-bit or 64-bit) for your software and operating system.
Note: Before applying this hotfix to your Autodesk product, youmust install service pack 1-below (or SP1.1 for AutoCAD and AutoCAD LT).
ACA2013 Update 1: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20556359&linkID=9240658
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
stensq
in reply to: MichaelBussiere2
Will this Hotfix work with Autocad Architecture 2012?
This will work with the following products,
Applies to:
AutoCAD® 2013
AutoCAD® Architecture 2013
AutoCAD® Civil 3D® 2013
AutoCAD® Electrical 2013
AutoCAD LT® 2013
AutoCAD® Map 3D 2013
AutoCAD® Mechanical 2013
AutoCAD® MEP 2013
AutoCAD® P&ID 2013
AutoCAD® Plant 3D 2013
AutoCAD® Raster Design 2013
AutoCAD® Structural Detailing 2013
AutoCAD® Utility Design 2013
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
DGArch
Zoom is too fast in constrained orbit mode, and too slow in walk mode (AutoCad Architecture 2009) is there a fix for this, or has this issue been remedied in later versions?
On a separate (somewhat related) topic, I can't edit (very easily, if at all) 3D models while in perspective view- has this issue been remedied in a newer version of Architecture?
”Boost
