AutoCAD Architecture General Discussion
Distinguished Contributor
diesellam
Message 1 of 7 (333 Views)
Accepted Solution
3d pipe appears to be 2d line
333 Views, 6 Replies
04-25-2012 10:21 AM
Please see the attached file.
Whenever I xref this file or copy this pipe and paste it to the other, the pipe appears to be a single line, what's the reason of it?  I have all of the object enablers loaded.  This is the only file that keeps acting like this, any idea?  This is from the subs, so it's not generated from Autodesk softwares. it's a converted DWG file.
Thanks in advance.
That's most of what we needed to know from your file, what type of template you are using and it sounds like it's an AutoCAD Architecture template.  You do need the MEP displays, but do not need them in the Architecture template.  Select the MEP xref inside your file.  Right-click and select "Edit Object Display."  A dialog box pops up.  At the top, there is a checkbox for "Override display in host drawing" (your drawing).  Enable that checkbox, and then below that is the list of displays from the MEP xref file.  Select on "MEP Design."  Ok out.  Then type in OBJRELUPDATE enter enter.  That regenerates the MEP model.  The pipes should now appear 3D 2-line.or 1-line if the diameter is small.
Cool.  It works.  That's a good trick to know.  Thanks again for your detailed solution.
Product Support
Joshua.Benoist
Message 2 of 7 (310 Views)
Re: 3d pipe appears to be 2d line
04-27-2012 07:34 AM in reply to: diesellam
The sample drawing comes from AutoCAD MEP.  What template are you using in AutoCAD Architecture?  Some templates do not have the AEC displays and the pipe will display as a single line.  Please attach a copy of your file and we can take a look at it.
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Support Specialist
Product Support
Autodesk, Inc.
diesellam
Message 3 of 7 (301 Views)
04-27-2012 02:55 PM in reply to: diesellam
tThe file has already been attached in my initial message of this post.
Product Support
Joshua.Benoist
Message 4 of 7 (290 Views)
04-30-2012 06:35 AM in reply to: diesellam
You provided an AutoCAD MEP file.  The pipe appears as 3D in this file.  You mentioned you were xreffing this MEP file into one of your own?  That's where it appears as 2D, if we understand you.  It's your file that we need, not the sbu-contractor's MEP file.
Joshua Benoist, PE
Product Support
Autodesk, Inc.
diesellam
Message 5 of 7 (288 Views)
04-30-2012 08:12 AM in reply to: diesellam
I see.  I guess once I Xref it to AutoCAD archtiecture, all of the AutoCAD MEP files will come in as single lines.
Since I don't have AutoCAD MEP, what's the alternative solution?
Product Support
Joshua.Benoist
Message 6 of 7 (286 Views)
04-30-2012 08:30 AM in reply to: diesellam
Joshua Benoist, PE
Product Support
Autodesk, Inc.
diesellam
Message 7 of 7 (282 Views)
04-30-2012 08:42 AM in reply to: Joshua.Benoist
Post to the Community
New Post
Need installation help?
