AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
3D pinwheel at 0,0
3 REPLIES 3
bluefox
7391 Views, 3 Replies
3D pinwheel at 0,0
I'm working in a drawing that someone else started. At 0,0, there's a white pinwheel-looking object that stays the same size relative to drawing space if you zoom in or out. I can't select it, so I can't delete it. I looked at it in 3D view, and it's like an inverted cone with a line extending out of it, with the point of the cone at 0,0,0. All layers are on and thawed.
How do I get rid of this?
Thanks.
3 REPLIES 3
KathyMoffa
in reply to: bluefox
Set geomarkervisibiliy to 0 to turn it off.  It only shows if it's to one and you have set a geographic location in the drawing.
bluefox
in reply to: KathyMoffa
Thanks a lot Kathy. I've never heard of that command and have no idea why anyone would have turned it on in the first place.
bluefox
Also Kathy, I just found out that the command I should be looking for is GEOGRAPHICLOCATION. It actually lets me delete the marker completely. But still thanks, I would've never found out about it without your insight.
”Boost
