If I create a drawing in AutoCAD Architecture 2010 on a 64 bit machine is there any way I can still plot using my old 32 bit printers?
I'm thinking print to dwf or PDF then open the file on my old 32 bit machine for printing?
Solved by pendean. Go to Solution.
A printer is a printer: you just need to get the correct driver in whatever operating system you are using.
