I have a brand new cpu running windows 7- 64 bit, nvidia geoforce 260 card (just updated) and brand new architecture 2011 software. Every time i place a dimension, move or modify one, it has a three second delay. Everything else works relatively well, only minor delays here and there which i assume are normal.
Any ideas on how to fix this? Thank you!
Solved by John.W.Mumaw. Go to Solution.
Do you have the properties palette open? If so try collapsing the "Lines and arrows" section.
I'm glad it worked, but the credit isn't mine. I myself found it in this discussion group a few months back.
John
