AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
3-D view sheet and Labels unit
1 REPLY 1
230 Views, 1 Reply
Hi, there are two questions I want to ask.
1. How to create 3-D view(such as SW Isometric view) sheet?
2. How to change elevation Labels data's unit? For example: I want to use 'm' as the unit of elevation Labels, and at the same time,use 'mm' as my AEC dimensions unit.
thank you!
1 REPLY 1
1. In your tabbed sheet in paperspace, create a view MVIEW and double click
into it and then use the view commands to set it up as you like. Once
happy, doubel click outside the viewport, select the viewport and right
click, then lock it so you don't loose the view setting.
2. Don't use them but one option is to use/create a new property data format
and scale the result by .001 and show 2 or 3 decimal places. You would need
to substitute that one for the one used in the Elevation Label. An easy way
to do that is to use a blank drawing, insert the elevation label, make the
change to the MVB and the PDF and then change both names in the style
manager. Then you can copy it back into your drawing, select the ones to
change and just change the style name to the inserted one and you are done.
wrote in message news:6311414@discussion.autodesk.com...
dimensions unit.
thank you!
”Boost
